SetDisabled Method
The SetDisabled method sets the disabled state of an item.
    SKMenu.SetDisabled(commandID, bool)
    commandID UINT value that contains the command ID of the item.
    bool Boolean value that specifies the disabled state.
    The following example creates a HTML dialog containing a menu with submenus, an item can be disabled and enabled.
       switch (ai_CommandID)
          case 1:
            alert('Item 1');
            break;
          case 3:
            mySubMenu.SetDisabled(1, !mySubMenu.GetDisabled(1));
            break;
    mySubMenu.InsertString(3,1, "Say Item 1", "");
    mySubMenu.InsertString(4,3, "Enable/Disable Item 1", "");
    mydialog.Title = true;
