ShowPopupMenu Method
The ShowPopupMenu method shows the popup menu.
    [commandID=] SKMenu.ShowPopupMenu(x, y)
    x Integer value that contains the horizontal position.
    y Integer value that contains the vertical position.
    Returns an UINT value containing the command ID of the popup menu.
    Use this method if the popup menu is not used as a submenu.
    The following example shows a context menu when the right mouse button is clicked.
    mySubMenu.InsertString(2,1, "Entry 1", "");
    mySubMenu.InsertString(3,2, "Entry 2", "");
    mySubMenu.InsertString(4,3, "Entry 3", "");
    mySubMenu.InsertString(5,4, "Entry 4", "");
    mySubMenu.InsertString(6,5, "Entry 5", "");
    function showmenu()
       if (event.button == 2)
          xpos = event.clientX;
          ypos = event.clientY + 120;
          cmdID = mySubMenu.ShowPopupMenu(xpos, ypos);
    <body onmousedown="showmenu()">
    Click the right mouse button to show a popup menu.
