BackgroundColor Property
The BackgroundColor property contains the color for the background of the progress bar.
document.all["id_name"].BackgroundColor [=color]
ColorValue that specifies or retrieves the background color.
ColorValue: An RGB (Red, Green, Blue) 32-bit color value that defines
a solid color. Each of the Red, Green, Blue portions represents the color intensity between
0 and 255 (or 0x00 to 0xff hexadecimal). The RGB color value can be calculated: ColorValue =
Red + Green*256 + Blue*65536. Please note that this representation differs from HTML color
values, which are hexadecimal RRGGBB.
The following example shows the BackgroundColor property when the link is clicked.
function ShowProp()
alert(document.all['id_SKProgressBarControl'].BackgroundColor);
function Start()
<br><br><br>
<div id="id_info">
<a href="javascript:ShowProp()">Show BackgroundColor property</a>
