BlockSize Property
The BlockSize property contains a value for the size of the blocks used to display the progress.
document.all["id_name"].BlockSize [=long]
Long value that specifies or retrieves the size of each block.
The following example shows the BlockSize property when the link is clicked.
function ShowProp()
alert(document.all['id_SKProgressBarControl'].BlockSize);
function Start()
<PARAM NAME="Caption" VALUE="Caption">
<PARAM NAME="Text" VALUE="Text">
<br><br><br>
<div id="id_info">
<a href="javascript:ShowProp()">Show BlockSize property</a>
