BlockSpace Property
The BlockSpace property contains a value for the space between the single blocks.
document.all["id_name"].BlockSpace [=long]
Long value that specifies or retrieves the space size.
The following example shows the BlockSpace property when the link is clicked.
function ShowProp()
alert(document.all['id_SKProgressBarControl'].BlockSpace);
function Start()
<br><br><br>
<div id="id_info">
<a href="javascript:ShowProp()">Show BlockSpace property</a>
