BorderWidth Property
The BorderWidth property contains a value for the width of the border of the progress bar.
    document.all["id_name"].BorderWidth [=long]
    Long value that specifies or retrieves the width of the border.
    The following example shows the BorderWidth property when the link is clicked.
    function ShowProp()
       alert(document.all['id_SKProgressBarControl'].BorderWidth);
    function Start()
    <br><br><br>
    <div id="id_info">
    <a href="javascript:ShowProp()">Show BorderWidth property</a>
