Color2 Property
The Color2 property contains the end color of the progress bar (at 100%).
    document.all["id_name"].Color2 [=color]
    ColorValue that specifies or retrieves the background color.
    ColorValue: An RGB (Red, Green, Blue) 32-bit color value that defines a solid color. Each of the Red, Green, Blue portions represents the color intensity between 0 and 255 (or 0x00 to 0xff hexadecimal). The RGB color value can be calculated: ColorValue = Red + Green*256 + Blue*65536. Please note that this representation differs from HTML color values, which are hexadecimal RRGGBB.
    The following example shows the Color2 property when the link is clicked.
    function ShowProp()
       alert(document.all['id_SKProgressBarControl'].Color2);
    function Start()
    <br><br><br>
    <div id="id_info">
    <a href="javascript:ShowProp()">Show Color2 property</a>
