Enabled Property
The Enabled property indicates whether the progress bar is enabled.
document.all["id_name"].Enabled [=bool]
Boolean value that specifies or retrieves the enabled status.
The following example shows the Enabled property when the link is clicked.
function ShowProp()
alert(document.all['id_SKProgressBarControl'].Enabled);
function Start()
<br><br><br>
<div id="id_info">
<a href="javascript:ShowProp()">Show Enabled property</a>
