FrameStyle Property
The FrameStyle property contains information about the layout style used for the frame of the progress bar.
document.all["id_name"].FrameStyle [=long]
Long with the following predefined values:
No FrameStyle = 0,
Single FrameStyle = 1,
3D FrameStyle = 2.
The following example shows the FrameStyle property when the link is clicked.
function ShowProp()
alert(document.all['id_SKProgressBarControl'].FrameStyle);
function Start()
<br><br><br>
<div id="id_info">
<a href="javascript:ShowProp()">Show FrameStyle property</a>
