InnerBorder Property
The InnerBorder property contains the size of the inner border of the progress bar.
    document.all["id_name"].InnerBorder [=long]
    Long value that specifies or retrieves the inner border size.
    The following example shows the InnerBorder property when the link is clicked.
    function ShowProp()
       alert(document.all['id_SKProgressBarControl'].InnerBorder);
    function Start()
    <br><br><br>
    <div id="id_info">
    <a href="javascript:ShowProp()">Show InnerBorder property</a>
