Orientation Property
The Orientation property contains the orientation of the progress bar.
document.all["id_name"].Orientation [=long]
Long that is 0 for a horizontal orientation.
1 for a vertical orientation.
The following example shows the Orientation property when the link is clicked.
function ShowProp()
alert(document.all['id_SKProgressBarControl'].Orientation);
function Start()
<br><br><br>
<div id="id_info">
<a href="javascript:ShowProp()">Show Orientation property</a>
