OuterBorder Property
The OuterBorder property contains the size of the outer border of the progress bar.
document.all["id_name"].OuterBorder [=long]
Long that specifies or retrieves the outer border size.
The following example shows the OuterBorder property when the link is clicked.
function ShowProp()
alert(document.all['id_SKProgressBarControl'].OuterBorder);
function Start()
<br><br><br>
<div id="id_info">
<a href="javascript:ShowProp()">Show OuterBorder property</a>
