Progress Property
The Progress property contains the current progress value of the progress bar.
document.all["id_name"].Progress [=long]
Long value that specifies or retrieves the actual progress.
The following example shows the Progress property when the link is clicked.
function ShowProp()
alert(document.all['id_SKProgressBarControl'].Progress);
function Start()
<br><br><br>
<div id="id_info">
<a href="javascript:ShowProp()">Show Progress property</a>
