Style Property
The Style property contains information about the layout style of the progress bar.
    document.all["id_name"].Style [=long]
    Long value that is 0 for a solid one color style.
    1 for a gradient style, changing from Color1 to Color2.
    The following example shows the Style property when the link is clicked.
    function ShowProp()
       alert(document.all['id_SKProgressBarControl'].Style);
    function Start()
    <br><br><br>
    <div id="id_info">
    <a href="javascript:ShowProp()">Show Style property</a>
