Transparent Property
The Transparent property contains information about the transparency status of the progress bar.
document.all["id_name"].Transparent [=boolean]
Boolean value. True if transparency is set.
False if no transparency is set.
The following example shows the Transparent property when the link is clicked.
function ShowProp()
alert(document.all['id_SKProgressBarControl'].Transparent);
function Start()
<br><br><br>
<div id="id_info">
<a href="javascript:ShowProp()">Show Transparent property</a>
