SKResize ActiveX Control
This control enables resizing a SiteKiosk browser window or
SKHTMLDialog.
The following table lists the members provided by the SKResize ActiveX control.
Properties |
Description |
Enabled |
Whether resizing is enabled. |
ResizeMode |
Border or corner to resize. |
Visible |
Whether the resize icon is visible. |
This ActiveX control is available in the form of scripts that can be used in combination with SiteKiosk.
Use the SKResize control for resizing functionality in a SiteKiosk window or SKHTMLDialog.
To initialize the ActiveX control use the OBJECT tag and, in particular, the classID to identify the control.
Note that you can not resize the SiteKiosk main browser window.
CLSID
A8103F81-00FF-45b9-995C-E7FF7D7FE8D8
The following example displays an image that can be clicked to resize the current window.
<OBJECT ID="SKResize" width="16" height="16"
CLASSID="CLSID:A8103F81-00FF-45b9-995C-E7FF7D7FE8D8">
<PARAM NAME="Enabled" VALUE="1">
<PARAM NAME="ResizeMode" VALUE="8">
<PARAM NAME="Visible" VALUE="1">
Click the icon the resize the window.
