AutoLogon Property
The AutoLogon property indicates whether the windows logon is done automatically when the computer is started.
SiteKiosk.StartSettings.AutoLogon [=bool]
Boolean value that specifies or retrieves the AutoLogon status.
The following example determines if the windows logon will be done automatically when the computer is started.
alert(SiteKiosk.StartSettings.AutoLogon);
