ConfigPath Property
The ConfigPath property contains the absolute path of the currently used SiteKiosk configuration file.
SiteKiosk.StartSettings.ConfigPath [=str]
String that specifies or retrieves the path.
The following example shows the path of the currently used configuration file.
alert(SiteKiosk.StartSettings.ConfigPath);
