ForceStartSettings Property
The ForceStartSettings property indicates whether the start settings dialog is shown when SiteKiosk is started.
SiteKiosk.StartSettings.ForceStartSettings [=bool]
Boolean value that specifies or retrieves the ForceStartSettings status.
The following example determines if the start settings dialog is shown when SiteKiosk is started.
alert(SiteKiosk.StartSettings.ForceStartSettings);
