KeyBlockingOnStartup Property
The KeyBlockingOnStartup property indicates whether the keyboard is blocked while Windows is starting.
    SiteKiosk.StartSettings.KeyBlockingOnStartup [=bool]
    Boolean value that specifies or retrieves the blocking
    status.
    The following example determines if the keyboard is blocked while Windows is starting.
    alert(SiteKiosk.StartSettings.KeyBlockingOnStartup);
