ResetStartSettings Property
The ResetStartSettings property indicates whether the start settings should be reset.
    SiteKiosk.StartSettings.ResetStartSettings [=bool]
    Boolean value that specifies or retrieves the
    reset status.
    The following example determines if the start settings should be reset.
    alert(SiteKiosk.StartSettings.ResetStartSettings);
