RunMode Property
The RunMode property contains the SiteKiosk starting mode.
    SiteKiosk.StartSettings.RunMode [=long]
    Long value that specifies or retrieves the run mode.
    Possible run modes:
    0 = Manually
    1 = Autostart
    2 = Shell-Replacement
    The following example shows how SiteKiosk is started.
    alert(SiteKiosk.StartSettings.RunMode);
