BackColor Property
The BackColor property contains the color for the background of the StaticText.
document.all["id_name"].BackColor [=color]
ColorValue that specifies or retrieves the background color.
Note that the BackStyle property should not be 0 for the BackColor property if it is to take any effect.
ColorValue: An RGB (Red, Green, Blue) 32-bit color value that defines
a solid color. Each of the Red, Green, Blue portions represents the color intensity between
0 and 255 (or 0x00 to 0xff hexadecimal). The RGB color value can be calculated: ColorValue =
Red + Green*256 + Blue*65536. Please note that this representation differs from HTML color
values, which are hexadecimal RRGGBB.
The following example changes the BackColor property on a mouse click.
function changeBackColor()
if(document.all["id_StaticText"].BackColor == 65280)
document.all["id_StaticText"].BackColor = 255;
document.all["id_StaticText"].Text =
document.all["id_StaticText"].Text;
else
document.all["id_StaticText"].BackColor = 65280;
<OBJECT id="id_StaticText" width="170" height="12"
style="padding:0; margin:0; display:inline;"
classid="CLSID:2D6F85AB-07AB-4417-85E3-7F2400474A63">
<PARAM NAME="BackStyle" VALUE="1">
<PARAM NAME="BackColor" VALUE="255">
<PARAM NAME="FontName" VALUE="Times New Roman">
<PARAM NAME="FontSize" VALUE="8.00">
<PARAM NAME="FontBold" VALUE="0">
<PARAM NAME="FontItalic" VALUE="0">
<PARAM NAME="FontUnderline" VALUE="0">
<PARAM NAME="FontWeight" VALUE="500">
<PARAM NAME="ForeColor" VALUE="0">
<PARAM NAME="Text" VALUE="Default text if necessary">
<div onclick="changeBackColor()">Click!</div>
