Font Property
The Font property contains the font of the displayed text.
document.all["id_name"].Font [=IFontDisp]
IFontDisp that specifies or retrieves the font for the text.
Since the Font property is an IFontDisp interface, access to the properties of the interface is possible. They are as follows:
Name, Size, Bold, Italic, Underline, Strikethrough, Weight and Charset.
The following example creates a StaticText ActiveX Control to demonstrate the possibilities. In this case the font name will be changed after 10 seconds and the text be displayed with the new font.
function changeFont()
if(document.all["id_StaticText"].Font.Name ==
"Times New Roman")
document.all["id_StaticText"].Font.Name = "Arial";
document.all["id_StaticText"].Text =
document.all["id_StaticText"].Text;
else
"Times New Roman";
<OBJECT id="id_StaticText" width="170" height="12"
style="padding:0; margin:0; display:inline;"
classid="CLSID:2D6F85AB-07AB-4417-85E3-7F2400474A63">
<PARAM NAME="BackStyle" VALUE="0">
<PARAM NAME="BackColor" VALUE="0">
<PARAM NAME="FontName" VALUE="Times New Roman">
<PARAM NAME="FontSize" VALUE="8.00">
<PARAM NAME="FontBold" VALUE="0">
<PARAM NAME="FontItalic" VALUE="0">
<PARAM NAME="FontUnderline" VALUE="0">
<PARAM NAME="FontWeight" VALUE="500">
<PARAM NAME="ForeColor" VALUE="0">
<PARAM NAME="Text" VALUE="Default text if necessary">
<div onclick="changeFont()">Click to change fonts!</div>
