CloseButton Property
The CloseButton property indicates whether the tooltip contains a close button.
    Tooltip.CloseButton [=bool]
    Boolean value that specifies or retrieves the CloseButton status.
    This property is available under Windows XP only.
    The following example shows a tooltip containing a close button when the mouse enters the text.
    <span id='mydiv' onMouseEnter='OnMouseEnter()'
    onMouseLeave='OnMouseLeave()' onMouseMove='OnMouseMove()'>
    Move the mouse over here.
    </span>
    function OnMouseEnter()
       myToolTip = SiteKiosk.SiteKioskUI.CreateToolTip();
       myToolTip.Balloon = true;
       myToolTip.NoAnimate = false;
       myToolTip.NoFade = false;
       myToolTip.NoPrefix = false;
       myToolTip.MaxWidth = 150;
       myToolTip.Title = "Title";
       myToolTip.Text = "This is the content";
       myToolTip.Icon = 1;
       myToolTip.CloseButton = true;     // Windows XP only
       myToolTip.SetMargin(5, 5, 5, 5);
       myToolTip.SetPosition(event.screenX, event.screenY);
       myToolTip.Show();
    function OnMouseMove()
    function OnMouseLeave()
       myToolTip.Hide();
