MaxWidth Property
The MaxWidth property contains the maximum width of the tooltip.
    Tooltip.MaxWidth [=long]
    Long value that specifies or retrieves the maximum width.
    When the maximum width is reached, a line break is inserted.
    The following example shows a wide tooltip when the mouse enters the text.
    <span id='mydiv' onMouseEnter='OnMouseEnter()'
    onMouseLeave='OnMouseLeave()' onMouseMove='OnMouseMove()'>
    Move the mouse over here.
    </span>
    function OnMouseEnter()
       myToolTip = SiteKiosk.SiteKioskUI.CreateToolTip();
       myToolTip.Balloon = true;
       myToolTip.NoAnimate = false;
       myToolTip.NoFade = false;
       myToolTip.NoPrefix = false;
       myToolTip.MaxWidth = 300;
       myToolTip.Title = "Title";
       myToolTip.Text = "This is the content. The maximum width " +
                        "of this tooltip is exactly 300 pixel.";
       myToolTip.Icon = 1;
       myToolTip.CloseButton = true;     // Windows XP only
       myToolTip.SetMargin(5, 5, 5, 5);
       myToolTip.SetPosition(event.screenX, event.screenY);
       myToolTip.Show();
    function OnMouseMove()
    function OnMouseLeave()
       myToolTip.Hide();
