Font Property
The Font property contains information about the font used for text in the address field.
document.all["id_name"].Font [=IFontDisp]
IFontDisp that specifies or retrieves the font used for the text.
Since the Font property is an IFontDisp interface, access to the properties of the interface is possible. They are as follows:
Name, Size, Bold, Italic, Underline, Strikethrough, Weight, and Charset.
The following example shows the FontName property when the link is clicked.
function ShowProp()
alert(document.all['URLComboBox'].Font.Name);
<OBJECT ID="URLComboBox" width="300" height="22px"
CLASSID="CLSID:973BD82B-0F81-4C42-A222-C42CA47DA1D3">
<PARAM NAME="BackColor" value="16777215">
<PARAM NAME="FontName" VALUE="Tahoma">
<PARAM NAME="FontSize" VALUE="8.00">
<PARAM NAME="FontBold" VALUE="0">
<PARAM NAME="FontItalic" VALUE="0">
<PARAM NAME="ForeColor" VALUE="65280">
<a href="javascript:ShowProp()">Show FontName property</a>
