URLs Object
The URLs object contains predefined URLs used by SiteKiosk.
    This object is available through the main object SiteKiosk. Use the URLs object to receive the predefined URLs.
    The following example shows the URL of the default search engine in an alert window.
    alert(SiteKiosk.URLs.Search);
