CloseHtmlDialogs Method
The CloseHtmlDialogs method closes all HTML dialogs of a specified type.
    SiteCafe.UserInterface.CloseHtmlDialogs(dtype)
    dtype String that specifies the type of dialog.
    You can handle existing dialogues defined in the browser skin files or own dialogs.
    The following example closes all existing "actionforbidden" HTML dialogs.
    SiteCafe.UserInterface.CloseHtmlDialogs("actionforbidden");
