CreatePopupMenu Method
The CreatePopupMenu method creates an object that contains a popup menu.
[obj=] SiteCafe.UserInterface.CreatePopupMenu()
Returns a SKMenu object that represents the new popup menu.
A popup menu can be used as a submenu of a normal menu.
The following example creates a HTML dialog containing a menu with submenus.
switch (ai_CommandID)
case 3: alert('Bye'); break;
mySubMenu = SiteCafe.UserInterface.CreatePopupMenu();
myMenu = SiteCafe.UserInterface.CreateMenu();
mydialog = SiteCafe.UserInterface.CreateHTMLDialog();
mydialog.Title = true;
