IsDialogRunning Method
The IsDialogRunning method returns whether a dialog of a specified type is running.
[bool=] SiteCafe.UserInterface.IsDialogRunning(dtype)
dtype |
String that specifies the type of dialog. |
Returns a Boolean value that indicates whether a dialog of the specified type is running.
You can handle existing dialogs defined in the browser skin files or own dialogs.
The following example determines if an "actionforbidden" dialog exists and shows it in an alert window.
alert(SiteCafe.UserInterface.IsDialogRunning("actionforbidden"));
