OpenHelp Method
The OpenHelp method opens a help file.
SiteCafe.UserInterface.OpenHelp(helpfile, topic)
helpfile |
String that specifies the path to the helpfile. |
topic |
String that specifies the topic. |
The help file must be a .chm file.
The following example opens a helpfile.
SiteCafe.UserInterface.OpenHelp("c:/helpfile.chm", "Topic");
