Name Property
The Name property contains the name of the property.
    UserProperty.Name [=str]
    Long value that specifies or retrieves the name.
    The following example displays the name of the first user's first property.
    user = SiteCafe.Server.Users.GetUserByIndex(1);
    properties = user.GetProperties(1, 10);
    alert(properties.Item(1).Name);
