Value Property
The Value property contains the value of the property.
UserProperty.Value [=var]
String or Long value that specifies or retrieves the value.
The following example displays the value of the first user's first property.
user = SiteCafe.Server.Users.GetUserByIndex(1);
properties = user.GetProperties(1, 10);
alert(properties.Item(1).Value);
