OnUserChanged Event
Fires when a user changed.
SiteCafe.Server.Users.OnUserChanged = handler
index |
Long value that contains the user index. |
flags |
Long value that contains the change flags. |
Possible flags are:
1 : inserted
2 : updated
3 : deleted
The following example displays the index and flags when a user changed.
SiteCafe.Server.Users.OnUserChanged = OnUserChanged;
function OnUserChanged(index, flags)
alert("User: " + index);
alert("Flags: " + flags);
