OnUserPropertyChanged Event
Fires when a user property changed.
    SiteCafe.Server.Users.OnUserPropertyChanged = handler
    index Long value that contains the user property index.
    flags Long value that contains the change flags.
    Possible flags are:
    1 : inserted
    2 : updated
    3 : deleted
    The following example displays the property index and flags when a user property changed.
    SiteCafe.Server.Users.OnUserPropertyChanged = OnUserPropertyChanged;
    function OnUserPropertyChanged(index, flags)
       alert("User property: " + index);
       alert("Flags: " + flags);
