BackColor Property
The BackColor property contains the background color used for the icon.
    document.all['icon_id'].BackColor [=color]
    ColorValue that specifies or retrieves the background color.
    ColorValue: An RGB (Red, Green, Blue) 32-bit color value that defines a solid color. Each of the Red, Green, Blue portions represents the color intensity between 0 and 255 (or 0x00 to 0xff hexadecimal). The RGB color value can be calculated: ColorValue = Red + Green*256 + Blue*65536. Please note that this representation differs from HTML color values, which are hexadecimal RRGGBB.
    The following example shows how to use this control in the InsertWindow function of the default skin file's tray window.
    <OBJECT id='windowicon" + ak_WindowInfo.Handle + "' width='16px'
    height='16px' CLASSID='CLSID:4688E264-206D-4D3A-B244-784ECFFD4746'>
      <PARAM NAME="BackColor" VALUE="16777215">
