Close Method
The Close method closes an existing window.
    SiteKiosk.WindowList.Close(handle)
    handle Handle that represents a window.
    The main window can not be closed.
    The following example will close the current window when the link is clicked.
    function doClose()
       SiteKiosk.WindowList.Close(thiswindow.Handle);
    <a href="javascript:doClose();">Close this window</a>
