CloseStartedApplications Method
The CloseStartedApplications method closes all running applications that have been configured in the SiteKiosk configuration.
SiteKiosk.WindowList.CloseStartedApplications()
This method only affects applications that will be closed when the SiteKiosk screensaver becomes active.
You can define this modifying the window managment in the SiteKiosk configuration.
The following example will close all running applications that have been configured.
SiteKiosk.WindowList.CloseStartedApplications();
