IsMaximized Method
The IsMaximized method returns if an existing window is maximized.
    [bool=] SiteKiosk.WindowList.IsMaximized(handle)
    handle Handle that represents a window.
    Returns a Boolean value that indicates if the window is maximized or not.
    The following example shows the current maximized status in an alert window.
    alert(SiteKiosk.WindowList.IsMaximized(thiswindow.Handle));
