IsMinimized Method
The IsMinimized method returns if an existing window is minimized.
[bool=] SiteKiosk.WindowList.IsMinimized(handle)
handle |
Handle that represents a window. |
Returns a Boolean value that indicates if the window is minimized or not.
The following example shows the current minimized status in an alert window.
alert(SiteKiosk.WindowList.IsMinimized(thiswindow.Handle));
