MainWindow Property
The MainWindow property contains an object representing the main SiteKiosk window.
[obj=] SiteKiosk.WindowList.MainWindow
WindowInfo object that represents the main window.
The following example shows the window type of the main SiteKiosk window in an alert window.
mainwindow = SiteKiosk.WindowList.MainWindow;
alert(mainwindow.WindowType);
