OnActivate Event
Fires when a window is activated.
SiteKiosk.WindowList.OnActivate = handler
skwin |
WindowInfo object that represents the activated window. |
To activate a window means to focus it.
The following example counts the activations of windows that are not the main window.
<div id="act">Create new windows and focus them.</div>
var countactivate = 0;
SiteKiosk.WindowList.OnActivate = OnActivate;
function OnActivate(skwin)
mainwindow = SiteKiosk.WindowList.MainWindow;
if (skwin.Handle != mainwindow.Handle)
countactivate++;
act.innerHTML = countactivate;
