OnMinMax Event
Fires when a window is minimized or maximized.
    SiteKiosk.WindowList.OnMinMax = handler
    skwin WindowInfo object that represents the activated window.
    showflags Long value that contains the show flags.
    The following example shows an alert window when a window is minimized or maxmized.
    SiteKiosk.WindowList.OnMinMax = OnMinMax;
    function OnMinMax(skwin, showflags)
       alert("new show flags: " + showflags);
