OnRemove Event
Fires when a window is closed.
    SiteKiosk.WindowList.OnRemove = handler
    skwin WindowInfo object that represents the closed window.
    The following example counts all closed windows.
    <div id="rem">Create new windows and close them.</div>
    var countclosed = 0;
    SiteKiosk.WindowList.OnRemove = OnRemove;
    function OnRemove(skwin)
       countclosed++;
       rem.innerHTML = countclosed;
