IsCardValid Method
The IsCardValid method returns whether the inserted SmartCard is valid.
    [bool=] SiteKiosk.Plugins("SiteCash").Devices("ACOS").IsCardValid()
    Returns a Boolean value that indicates if the SmartCard is valid.
    The following example determines if the inserted SmartCard is valid and shows it in an alert window.
    smartcard = SiteKiosk.Plugins("SiteCash").Devices("ACOS");
    alert(smartcard.IsCardValid());
