ACOS Object
The ACOS object controls the ACOS SmartCard device.
The following table lists the members provided by the ACOS object.
This object is available through the collection Devices.
Use the ACOS object to check for a SmartCard, to change the credit or to get or set information about the owner.
This device can be activated in the SiteKiosk configuration.
The following example determines if a SmartCard is inserted and shows it in an alert window.
smartcard = SiteKiosk.Plugins("SiteCash").Devices("ACOS");
alert(smartcard.IsCardInserted());
