OnCardInserted Event
Fires when a SmartCard is inserted.
SiteKiosk.Plugins("SiteCash").Devices("ACOS").OnCardInserted = handler
ctype |
Long value that contains the type of the inserted card. |
The following example shows an alert window when a SmartCard is inserted.
smartcard = SiteKiosk.Plugins("SiteCash").Devices("ACOS");
smartcard.OnCardInserted = OnCardInserted;
function OnCardInserted(cardtype)
alert(cardtype + " card inserted");
