OnTransactionFinished Event
Fires when a credit transaction is finished.
SiteKiosk.Plugins("SiteCash").Devices("ACOS").OnTransactionFinished = h
id |
Long value that contains the transaction ID. |
success |
Boolean value that indicates if the transaction was successful. |
The following example shows an alert window when a transaction has been processed.
smartcard = SiteKiosk.Plugins("SiteCash").Devices("ACOS");
smartcard.OnTransactionFinished = OnTransactionFinished;
function OnTransactionFinished(id, success)
alert("Transaction " + id + " done, success: " + success);
