OnUserDataReady Event
Fires when a card has been read after insertion.
    SiteKiosk.Plugins("SiteCash").Devices("ACOS").OnUserDataReady = handler
    id Long value that contains the question ID.
    index Long value that contains the index number of the read data.
    data String that contains the read data.
    This event fires for each single data field that has been read.
    The following example shows all available user data in an alert window when a card has been inserted.
    smartcard = SiteKiosk.Plugins("SiteCash").Devices("ACOS");
    smartcard.OnUserDataReady = OnUserDataReady;
    function OnUserDataReady(id, index, data)
       alert(id + " " + index + " " + data);
